Please help... Overhaul on 03 5.7 hemi
Old Sep 24, 2013 | 12:32 AM
Prestondavidgreer's Avatar
Default Please help... Overhaul on 03 5.7 hemi
I am rebuilding a 5.7 hemi that came out of a 2003 dodge ram 1500..
Under the intake manifold there are 4 white plugs going into the block with bolts holding them down.. I broke one .. I can figure out what it is or where to buy one or how to remove it.. Any help would be greatly appreciated..
I can't figure out how to post a picture on here so if you would text me that would be fine if you need to see pic.. 2708757269 thanks
Old Sep 29, 2013 | 02:56 PM
bossdog's Avatar
Default white plugs
Those white plugs are where the solenoids go for the mds. They shut off the oil to the cylinders being de-activated. They will be at the dealer as they were used on automatic trannys only, not manuals.
knaffie
Dec 8, 2013 11:41 AM
unique10
Oct 21, 2013 06:29 PM
1Last69
Jan 7, 2011 06:37 PM
transamsam98
Jan 9, 2009 08:35 PM
