Please help... Overhaul on 03 5.7 hemi
I am rebuilding a 5.7 hemi that came out of a 2003 dodge ram 1500..
Under the intake manifold there are 4 white plugs going into the block with bolts holding them down.. I broke one .. I can figure out what it is or where to buy one or how to remove it.. Any help would be greatly appreciated.. I can't figure out how to post a picture on here so if you would text me that would be fine if you need to see pic.. 2708757269 thanks |
white plugs
Those white plugs are where the solenoids go for the mds. They shut off the oil to the cylinders being de-activated. They will be at the dealer as they were used on automatic trannys only, not manuals.
