External Engine Exhaust | Intakes | Pulleys | Ignition
OIL in Intake Manifold!!!
Old Jan 17, 2010 | 07:20 PM
graffiti oner's Avatar
Default OIL in Intake Manifold!!!
Need help ASAP. Why would there be a lot (I mean excessive amounts) of oil in an intake manifold from a 2006 300C. The manifold was removed and it literally dumped oil every where (4 ft x 4 ft). We've been trying to troubleshoot why the car bogged down/wouldn't start for a while, then got it to kick over but spewed smoke everywhere. Also, where can I find a manifold, found none on ebay or websites...thanks.
Old Mar 15, 2010 | 04:33 AM
Joeychgo's Avatar
Keep checking ebay, but you might have to get an OEM intake from the dealer.
Old Mar 15, 2010 | 08:49 AM
slowpoke96z28's Avatar
TECH Fanatic
only thing i could think of is if there was a lot of oil in the valve cover for some reason and the PCV valve sucked it up.
Old Apr 3, 2010 | 05:16 AM
CarsMakeLove's Avatar
Best option is to trust a good mechanic and assess the mechanic's records. If you trust the person, go have your car fixed there. There's nothing absolutely helpful you can search online without getting physical assistance from a trusted expert.
Old Apr 3, 2010 | 12:57 PM
sssalah's Avatar
Normal to some extent in these motors, thats why an oil catch can is highly recommended. Don't see why the op needs to change the mainfold, if only for the oil just clean and reinstall.
Old Oct 1, 2010 | 03:09 AM
01ssreda4's Avatar
Taxman20
Dec 26, 2014 09:44 AM
99VetteFRC
Dec 23, 2011 08:19 PM
69rrbruce
Sep 16, 2008 09:08 PM
Ed @ Late Model Speed
Mar 23, 2008 09:46 PM
