Internal Engine Blocks | Cylinder Heads | Rotating Assy | Camshafts
engine torque specifications
Old Mar 7, 2008 | 02:37 AM
300C_SRT8's Avatar
Default engine torque specifications
hey guys anyone can help me where to find the engine torque specifications for SRT8 please ??????
Old Mar 16, 2008 | 03:49 PM
skeletonizer's Avatar
What?
The output or the tq specs of the fasteners?
It's 420 ft-lbs.
Otherwise that's a lot of bolts.
Block Pipe Plugs---177 in/lbs
Camshaft Sprocket Bolt---90 ft/lbs
Camshaft Tensioner Plate---250 in/lbs
Timing Chain Case Cover Bolts---250 in/lbs
Conecting Rod Cap Bolts---33 ft/lbs + 60 degrees
Main Bearing Cap Bolts M12---??
Crossbolts M8---??
Cylinder Head Bolts M12---all to 25ft/lbs, then to 40ft/lbs then 90 degrees
M8---all to 15 ft/lbs then to 25 ft/lbs
Cylinder head cover bolts---70 in/lbs
Ehaust Manifold---70 in/lbs
Flexplate---70 ft/lbs
Flywheel---55 ft/lbs
Front insulator-through bolt/nut---70 ft/lbs
Front insulator to block---70 ft/lbs
Generator mount---40 ft/lbs
Intake manifold---check service manual procedure
Lifter guide holder---106 in/lbs
Oil pan---105 in/lbs
Dip stick tube---53 in/lbs
Oil drain plug---20 ft/lbs
Oil pump bolts---250 in/lbs
Oil pick up tube---250 in/lbs
Rear seal retainer---132 in/lbs
Rear insulator to bracket---50 ft/lbs
" " " Crossmember---30 ft/lbs
" " " Transmission---50 ft/lbs
" " Bracket Bolts---50 ft/lbs
Rocker Arm Bolts---195 in/lbs
Spark Plugs------
T-stat housing---250 in/lbs
Throttle body---105 in/lbs
Vibration damper---129 ft/lbs
Water pump---250 in/lbs
dodgeinfocenter
Jan 7, 2010 12:16 PM
dodgeinfocenter
Dec 18, 2009 01:24 PM
austinpowers
Mar 22, 2008 09:51 AM
Beast 2
Mar 30, 2007 08:40 PM
