engine torque specifications
hey guys anyone can help me where to find the engine torque specifications for SRT8 please ??????
What?
The output or the tq specs of the fasteners? It's 420 ft-lbs. Otherwise that's a lot of bolts. Block Pipe Plugs---177 in/lbs Camshaft Sprocket Bolt---90 ft/lbs Camshaft Tensioner Plate---250 in/lbs Timing Chain Case Cover Bolts---250 in/lbs Conecting Rod Cap Bolts---33 ft/lbs + 60 degrees Main Bearing Cap Bolts M12---?? Crossbolts M8---?? Cylinder Head Bolts M12---all to 25ft/lbs, then to 40ft/lbs then 90 degrees M8---all to 15 ft/lbs then to 25 ft/lbs Cylinder head cover bolts---70 in/lbs Ehaust Manifold---70 in/lbs Flexplate---70 ft/lbs Flywheel---55 ft/lbs Front insulator-through bolt/nut---70 ft/lbs Front insulator to block---70 ft/lbs Generator mount---40 ft/lbs Intake manifold---check service manual procedure Lifter guide holder---106 in/lbs Oil pan---105 in/lbs Dip stick tube---53 in/lbs Oil drain plug---20 ft/lbs Oil pump bolts---250 in/lbs Oil pick up tube---250 in/lbs Rear seal retainer---132 in/lbs Rear insulator to bracket---50 ft/lbs " " " Crossmember---30 ft/lbs " " " Transmission---50 ft/lbs " " Bracket Bolts---50 ft/lbs Rocker Arm Bolts---195 in/lbs Spark Plugs------ T-stat housing---250 in/lbs Throttle body---105 in/lbs Vibration damper---129 ft/lbs Water pump---250 in/lbs |
