Revs Out Of Control
Old 07-06-2009, 10:33 PM
Cammin Hemi's Avatar
Angry Revs Out Of Control
At times on the highway I'LL get the drive by wire symbol flashing & truck will die with no forewarning. It's just like the key is shut off. Starts back up ok like nothing happened. I get fault code p2173 for high airflow. Can find no vacumme leak. Truck will also rev out of control when shifting in to neutral at just about any speed. I have to shut it down. It also does not want to decelerate when letting off the gas. I can take my foot off the pedal at 30 to 40 mph and it takes blocks to slow down without braking. Any ideas? Is it the tune? Or will this engine ever run right with these modifications? I have also tried new AIT & Map sensors and a new t-body. Help!!
Cammin Hemi is offline
Old 07-08-2009, 10:32 AM
LS1Tech Sponsor
Mike@Diablosport's Avatar
Yes, it is something in the tune.
I assume you have a procharger?
I would contact your CMR tuner and see if he can help, if not, email me a copy of the tune and I'll get you fixed up.
Thanks
Mike
Mike@Diablosport is offline
Old 08-03-2009, 07:28 PM
5speedsilverado's Avatar
my moms truck had the problem with dieing for no reason, it was a tsb out for the truck
5speedsilverado is offline
badjuju342
06-02-2012 06:17 PM
RickyRam5.9
07-24-2010 08:44 PM
mariojmoe
03-24-2008 08:33 PM
Quick Reply: Revs Out Of Control
