Driving lights and light bars for Dodge Ram
No Off Road vehicle is complete until you have Off-Road Lights! It's a must have for any off-road enthusiast. Off road lights let you hit the trail safely in the nasty weather or cover of night. With heavy-duty casings and materials, these off road lights help blaze a trail through the mud and mess.
Unlike factory vehicle lighting, off-road lights can be pivoted in any direction you choose to see down a sudden drop off, to the sides to see around switchbacks, or when you need to look up from a dip. A strong lighting source from a high location allows you to make better decisions on the trails. Quality off-road lights should have lightweight composite construction so things don’t shift out of position or vibrate loose when bouncing around on the road. Higher-end lights offer the ability to focus and adjust the light beam for a wide spread or targeting one specific area with the intensity of a laser beam. Whether you want to set up off-road lights on your roof, front bumper, rear, or other areas, we have them for you. Here is the list of several interesting options: Lumen® - 51 Watt LED Round Off-Road Driving Light mounts easily on any pre-drilled holes atop headache racks, bull bars, or grille guards. Total LED power: 51 watts from 17 radially mounted pencil beam LEDs. http://www.carid.com/images/lumen/le...ing-lights.jpg KC HiLiTES® - Apollo Lights have 6" Round Slim Housings fitted with 55W or 100W Halogen Bulbs. http://www.carid.com/images/kc-hilites/lights/456.jpg ARB® - Intensity LED Light are equipped with 90 Watts bulbs, have amp draw 6.25A @ 14.4V, 32 LEDs, 8200 raw Lumens. http://www.carid.com/images/arb/off-...d-lights-4.jpg KC HiLiTES® - Pro Sport HID Lights have 6" or 8" Round Black Composite Polymax Housing and Super Bright 35W HID Bulb. http://www.carid.com/images/kc-hilites/lights/851.jpg For all Off-Road lights we carry click here: Off-Road Lights for Trucks & SUVs at CARiD.com Whether you're building a serious Baja racer or just want your truck to look suitable, another type of lights is definitely worth your attention – the Light bar. LED bars can accommodate round or rectangular rally style lights. Let's take a look at few options we carry: Smittybilt® - RPD Light Bar includes 3 light mounting tabs for lights up to 9" in diameter, manufactured from 1.5" diameter 0.120" wall thickness steel tubing. http://www.carid.com/images/smittybi...ford-f-150.jpg Smittybilt® - Street Light Bar includes 4 light mounting tabs that can accommodate up to a 9" diameter light, manufactured from 1.25" diameter 0.095" wall thickness steel tubing and have a high-gloss powdercoated finish. http://www.carid.com/images/smittybi...ford-f-150.jpg CARR® - Deluxe Light Bar holds up to 4 lbs of weight, have 7 pre-drilled holes for auxiliary lights and available in stylish XP4 Titanium Silver, XP3 Black, and XM3 Polished finishes. http://www.carid.com/images/carr/off...ght-bars-2.jpg Which one do you prefer? |
Make sure you are driving safe at night! Improve the style of your car and save 5% on all Lumen LED lights. Appy this CODE now: LUM-5OFF-DISC
Check all Lumen products here: Lumen® LED Bulbs, Off-Road Lights, LED Bars at CARiD.com http://www.carid.com/images/brands/l...sories_cat.jpg |
