Hawk Front Brake Pads - 300C, Charger, Challenger, Magnum
One set of Hawk Performance Brake pads for the following vehicles -
Hawk HB507F.711 fits: 2005-2010 Chrysler 300 2009-2011 Dodge Challenger 2006-2011 Dodge Charger 2005-2008 Dodge Magnum Part # is HB507F.711 •Unbeatable stopping power and brake life - 20-40% more powerful than the competition •Special ferro-carbon composite material minimizes friction and reduces brake fade and rotor warp •Low dust, virtually noise free •Ideal for use with high performance rotors •Fits like standard pads, installs in under 1 hour per pad •Lifetime Warranty against defects Hawk HPS (High Performance Street) Brake Pads are made exactly for that - high performance use on the street. Hawk draws from their long history in high-end aerospace, military, and racing brake technology in engineering the HPS series, and it shows. Hawk HPS Brake Pads blow away the competition in power, life span, and performance across the board. The key to the HPS Brake Pads' stopping force is their special ferro-carbon material. This uninque composite makes for less friction with a 20-40% increase in stopping power. This means much higher brake fade resistance, which in turn means better control and safety. HPS Brake Pads will last longer than the rest, and rotors will see much less warping. Your ears will thank you too - HPS Brakes are virtually silent. Hawk HPS Brake Pads are designed vehicle-specific to bolt onto your calipers like stock or standard replacement pads without any mods or other hassles. Plus, they're backed by a Lifetime Warranty against manufacturer defects. Never installed. $65.00 shipped in the 48 states. |
I assume these will fit a 06 300C AWD? (5.7)
Does it offer still available?if yes can you please provide me more information via PM.
