Please help... Overhaul on 03 5.7 hemi
I am rebuilding a 5.7 hemi that came out of a 2003 dodge ram 1500..
Under the intake manifold there are 4 white plugs going into the block with bolts holding them down.. I broke one .. I can figure out what it is or where to buy one or how to remove it.. Any help would be greatly appreciated..
I can't figure out how to post a picture on here so if you would text me that would be fine if you need to see pic.. 2708757269 thanks
white plugs
Those white plugs are where the solenoids go for the mds. They shut off the oil to the cylinders being de-activated. They will be at the dealer as they were used on automatic trannys only, not manuals.
