Vibration 5.7 in Magnum
Old 09-09-2018, 12:52 PM
Robert Houck's Avatar
Default Vibration 5.7 in Magnum
I had to have the engine replaced in my 2007 Magnum a Jasper long block engine was put in. I had the torque converter changed at the same time it is an aftermarket converter.
There was a vibration at around 2000rpm so the flex plate AND a second torque converter were put in the serpentine belt was removed, engine run but vibration was still there...………. WHAT COULD BE THE PROBLEM ????????????????
Robert Houck is offline
austinpowers
03-22-2008 09:51 AM
300C_SRT8
03-16-2008 03:49 PM
gremlinsteve
11-20-2007 03:53 PM
JDJP
01-14-2007 09:24 AM
David Hamburger
01-02-2007 04:22 PM
Quick Reply: Vibration 5.7 in Magnum
