Forced Induction Turbochargers | Superchargers
upcoming prochargers for HEMI!!!!!
Old 12-07-2006, 08:47 PM
Brent@LPE's Avatar
Default upcoming prochargers for HEMI!!!!!
ATI is proud to announce its HO Intercooled ProCharger systems for Dodge Hemi automotive and truck platforms. Initial applications will be introduced on the 5.7 liter Hemi Charger and Ram trucks. These systems produce 45-50% power gains on stock motors running pump gas with 6 psi of intercooled boost. Featuring the coolest charge air temperatures available, these systems deliver industry leading power gains and superior engine longevity.
Industry exclusive features include a 3-core air-to-air intercooler system, patented self-contained supercharger with 3-year warranty, and, on the Charger, a dedicated 8-rib supercharger drive with automatic belt tensioner. The HO Intercooled ProCharger systems are 100% complete, with supplemental injectors and programming to ensure maximum performance.
ProCharger systems feature easy installation, minimal relocation of components, no need to punch a hole in the oil pan, and avoid having to deal with all the complexity of an air-to-water intercooler. On the Charger, a Serpentine Race Kit, which is capable of much higher boost and power levels, is being designed for modified motor applications. It will also feature a dedicated 8 rib drive system and the powerful F-1 ProCharger.
Look for availability on these Hemi systems in early 2007. Also slated for future development are Hemi systems for Dodge Magnum, Chrysler 300 and 6.1 liter motors
Largest Power Gains, Coolest Charge Air Temperatures
Unmatched Technology
Thanks to relentless innovation, ProCharger technology is generations ahead of the competition. Our exclusive, patented, self-contained, gear-driven superchargers eliminate tapping into your oil pan, run cooler and produce more power than any of our competitor’s products. Our impellers are created with aircraft grade 7075 T-6 aluminum alloy for tremendous strength and performance. The top tier material used in the construction of every ProCharger billet impeller and compressor housing allows us to use higher step up ratios than the competition. This in turn allows increased boost levels and superior overall performance than other offerings on the market. Because of this unwavering commitment to excellence, ProCharger is the only manufacturer of self-contained superchargers offering a 3-year warranty to ensure years of trouble free performance.
We will hope to see this kits at PRI this weekend!!!
Brent@LPE is offline
Old 12-08-2006, 08:10 PM
Moderator
DriveATransAm's Avatar
do you know what they are using to tune it?
DriveATransAm is offline
Old 12-08-2006, 08:18 PM
LS1TECH Sponsor
foff667's Avatar
werd, I was asking around at SEMA about whats available & nobody really knew much. I'd definitly like to know whats out there or if its all just handheld canned tune stuff. Especially considering they are SD the tune would have to be pretty good especially in an FI application.
foff667 is offline
Old 12-08-2006, 08:27 PM
Moderator
the gsm piggyback is grenading motors left and right. i would think that ati would have a better system out.
i heard there was a company looking to convert to a maf (like the 5.0s) which would be sweet.
Old 12-09-2006, 05:53 PM
EPP
EPP's Avatar
Question
We had one of the GMS blowers on a Charger on our dyno, that let a rod go. The GMS is a pretty disappointing blower in my opinion. Bob
EPP is offline
Old 12-09-2006, 05:58 PM
EPP
EPP's Avatar
Question
http://www.exoticperformanceplus.com....html?item=726
For know, the ATI ProCharger method of tuning the Dodge engines will also be with a piggyback type of tune. Everyone is waiting for the Dodge software to be
reverse engineered. Bob
EPP is offline
Old 12-20-2006, 05:54 PM
EPP
EPP's Avatar
The truck units will be released very soon, within the next several months.
We checked out the Charger ProCharger assembly at the PRI show in Orlando, and it looks very nice, very clean in appearance. Much better looking than the GSM blower. Bob
EPP is offline
Old 12-20-2006, 08:54 PM
  #8
hemidup's Avatar
[QUOTE=DriveATransAm]the gsm piggyback is grenading motors left and right. i would think that ati would have a better system out.
It's not the Split Second piggyback that's wrecking the motors, it's the lack of fuel along with inexsperienced tuners.
hemidup is offline
Old 12-21-2006, 01:05 AM
  #9
fulson4's Avatar
the ati method of tuning is different than the gsm. the piggyback is completely different. it can't be tuned by the installer. it comes pretuned like the gsm. there are a limited number of tuners available for the piggy back that they use... in order to be able to tune you must go to a 3 day class for the piggyback system and meet certain qualifications. this is what i was informed. (not by ati)
[QUOTE=hemidup]
fulson4 is offline
Old 12-21-2006, 04:47 PM
  #10
Moderator
[QUOTE=hemidup]
it was my understanding that they cant richen up the front cylinders and lean out the rear ones with the piggback. their wideband is saying all is ok, even though the rears are being flooded and fronts are starving for fuel, partly thanks to the manifold style. when it comes out the end, its all averaged and it looks ok. maybe they need to put a sensor on each primary and can a tune that way.
Quick Reply: upcoming prochargers for HEMI!!!!!
