Internal Engine Blocks | Cylinder Heads | Rotating Assy | Camshafts
5.7 vs 6.1 cylinder heads?
Old Jan 20, 2007 | 08:02 PM
Brains's Avatar
TECH Senior Member
Default 5.7 vs 6.1 cylinder heads?
What's the differences between the heads, are they interchangeable?
Old Jan 21, 2007 | 07:22 PM
fulson4's Avatar
I know they are interchangeable i changed my 5.7 heads to 6.1 heads. i know the 6.1 heads are higher compression. they flow better as well.
Old Jan 21, 2007 | 09:47 PM
Beast 2's Avatar
Yes they will interchange. The 6.1 has bigger valves and flow more. They also have a smaller chamber so they increase compression on a 5.7. I wouldn't run the stock 6.1 heads on a stock 5.7 without an aftermarket controller to reduce timing. The HEMI Shop has a "big chamber" CNC head that is great for use on the 5.7.
Old Jan 22, 2007 | 09:09 AM
Brains's Avatar
TECH Senior Member
Good deal, I like options
Old Jan 22, 2007 | 11:11 PM
hemidup's Avatar
TECH Regular
The 6.1 will flow more CFM, but the 5.7 will have more air speed velocity.
Old Jan 27, 2007 | 11:00 PM
  #6
Sharadon's Avatar
Under 400 cu inch I'll take a ported 5.7 head over a 6.1 head any day.
Old Jan 28, 2007 | 12:58 PM
  #7
Brains's Avatar
TECH Senior Member
Ported with stock valves, or bigger? I've got my eyes set on building a stroker motor at some point, and need to get my ducks in a row before I start chunking down cash
Old Feb 12, 2007 | 12:16 AM
  #8
hemidup's Avatar
TECH Regular
I used 5.7 heads with 2.08" int and 1.62" exh. on my 6.1 stroked 392. I guess you could call it reversed engineering.
Old Mar 16, 2007 | 05:40 AM
  #9
1dirtyZ's Avatar
8 Second Club
any flow numbers for both?
Old Mar 22, 2007 | 10:51 PM
  #10
thehemi's Avatar
On The Tree
http://www.thehemi.com/57L/flow.php
http://www.thehemi.com/61L/flow.php
