Fuel injector breakthrough!
Old 07-24-2015, 03:02 PM
Reg A's Avatar
Default Fuel injector breakthrough!
Fuel injector breakthrough! TO: All and/or IC engine enthusiasts,
WOW what a day for you and me. I have just days ago confirmed an honest to God breakthrough using my own 2011 HEMI Charger at Andy Wicks Dyno-tune shop in Watertown, SD.
The pictures are self explanatory but I am talking about a simple device (which I call FI Blades) that turns an ordinary injector into a dual function FI allowing for actual externally tunable intra-port air flow control. This is my own patent pending concept.
While I will have to recommend professional installation, most semi-mechanically inclined people will have no problem installing them in less then an hour. After that tuning adjustments can be done in seconds.
These things create real torque + power you can feel.
Right now the apps I can supply are those that use the slender body FI with the long tip as pictured here. Can anyone tell me all the applications that currently use this injector and/or production #s for any application using tem?
I am accepting no-deposit pre-orders with a 4-6 week lead time. While results are guaranteed to vary I nonetheless guarantee they will work or I will return your money + the cost of the dyno time to prove it did not work. They are going to be $300.00 for a set of 8.
My Name is Reggie D. Huff, so call or email me with any questions. My Phone # is 330-373-8106
I am so sorry but I cannot get the damn power graph to attach. But I can email it. I will tell you it made power from top to bottom 20-28 ft/lbs @ the bottom end and about 7 HP @ the top and we have only scratched the surface!
Attached Thumbnails Fuel injector breakthrough!-single_cylinder_turned_right_dual_white_arrow_4_6.jpg   Fuel injector breakthrough!-single_installation_from_back_6_4.jpg
Reg A is offline
NemeSS
08-27-2018 04:43 AM
jsalvato1
04-12-2009 12:55 PM
Nasty N8
01-13-2007 03:20 PM
Quick Reply: Fuel injector breakthrough!
