5.7 vs 6.1 cylinder heads?
Old 01-20-2007, 08:02 PM
Brains's Avatar
Default 5.7 vs 6.1 cylinder heads?
What's the differences between the heads, are they interchangeable?
Brains is offline
Old 01-21-2007, 07:22 PM
fulson4's Avatar
I know they are interchangeable i changed my 5.7 heads to 6.1 heads. i know the 6.1 heads are higher compression. they flow better as well.
fulson4 is offline
Old 01-21-2007, 09:47 PM
Beast 2's Avatar
Yes they will interchange. The 6.1 has bigger valves and flow more. They also have a smaller chamber so they increase compression on a 5.7. I wouldn't run the stock 6.1 heads on a stock 5.7 without an aftermarket controller to reduce timing. The HEMI Shop has a "big chamber" CNC head that is great for use on the 5.7.
Beast 2 is offline
Old 01-22-2007, 09:09 AM
Brains's Avatar
Good deal, I like options
Brains is offline
Old 01-22-2007, 11:11 PM
hemidup's Avatar
The 6.1 will flow more CFM, but the 5.7 will have more air speed velocity.
hemidup is offline
Old 01-27-2007, 11:00 PM
Sharadon's Avatar
Under 400 cu inch I'll take a ported 5.7 head over a 6.1 head any day.
Sharadon is offline
Old 01-28-2007, 12:58 PM
Brains's Avatar
Ported with stock valves, or bigger? I've got my eyes set on building a stroker motor at some point, and need to get my ducks in a row before I start chunking down cash
Brains is offline
Old 02-12-2007, 12:16 AM
  #8
hemidup's Avatar
I used 5.7 heads with 2.08" int and 1.62" exh. on my 6.1 stroked 392. I guess you could call it reversed engineering.
hemidup is offline
Old 03-16-2007, 05:40 AM
  #9
8 Second Club
1dirtyZ's Avatar
any flow numbers for both?
1dirtyZ is offline
Old 03-22-2007, 10:51 PM
  #10
On The Tree
thehemi's Avatar
http://www.thehemi.com/57L/flow.php
http://www.thehemi.com/61L/flow.php
thehemi is offline
Quick Reply: 5.7 vs 6.1 cylinder heads?
