6.1 Cam
Henson motor sports in Tex has the best price. Ask for Art in the parts department
1800-530-5337.
You have MDS right? You can't use the 6.1 cam without replaceing the lifters and deleteing the mds option from the pcm. OR,, I'll check but I believe you can ground out the selenoid signal and put the non MDS plugs in the block. It involves removing the heads. So there's a little more to it.
1800-530-5337.
